ge_rik
Quite by coincidence, linking to another thread on lipo/li-ion batteries, ( https://www.gscalecentral.net/index.php?topic=301586.0 )I have just finished the wiring for another conversion of my former track-powered locos to battery power - using three 18650 li-ion batteries.
OK - she`s not looking very pretty as yet. When I stripped her down to remove the lead weights from the boiler, I also decided to rub down the paintwork as it was looking a bit chipped and tired.
Inside the saddle tank are the three 18650 li-ion batteries which deliver 11.2 volts. Doubt I could have inserted ten NiMh batteries into the same space. These Samsung batteries have solder tags but are unprotected. I could not find any protected tagged batteries.
So, I`ve connected a battery protection board. This monitors balance charging, discharging and protects against short circuits. It also has a heat sensor to check the temperature of the batteries during charging.
Finally, there`s the Deltang Rx65b combined receiver / ESC. This auto-senses the supply voltage and will also cut-off if the batteries fall below a safe level. The protection board and the receiver/controller slot into the lower half of the boiler beneath the saddle tank.
The charge socket has been installed beneath the saddle tank. I know it`s a bit prominent there, but there wasn`t really anywhere discreet to put it. Space is tight on this loco. The motor block is a ToyTrain 0-4-0 (from an OHO (Otto) loco). I`ve given her some test runs and she seems to perform well. Not sure if I can also fit in a MyLocoSound soundboard - I`d like to if I can. But she definitely needs a paint-job!
I`ll post more pics and a video once she enters service properly. Will be good to have the Hunslet back in service.
I know there are some who are deeply sceptical about using li-ion batteries in trains - but to be honest, I don`t think I would get the same level of power (11.2v 3Ah) in the same space with other battery technologies.
Rik
EDIT: I have a more detailed account of a similar conversion on my blog - http://riksrailway.blogspot.com/2015/03/how-i-converted-track-powered-loco-to.html
Which includes this circuit diagram for the battery protection board
Rik
