HELP! - Directional lighting - not quite right ...
steinz
Just purchased a 22900 Diesellok (whuch has factory-fitted MTS).
It works fine - except for the directional lighting.
In both Analogue and digital-mode the rear-lights stay lit all the time - regardless of the direction.
The front-lights, however, work okay (both digital+analogue) :)
Before taking apart to investigate, can anyone help as to what might be the cause,
Many thanks
I would agree with Cliff, initially reset the decoder to factory defaults (set CV55 to 55 I think).
That sounds about right MUns.
Other CVs to note are CV52 & 53 which control the operation of the lights on most LGB decoders...
Normal values are
for CV52 - 128 Front Light control: Switch on/off using Light button (On only if direction is forward)
for CV53 - 64 Rear Light control: Switch on/off using Light button (On only if direction is reverse)
Many thanks for all the help on this one ...
Initially, I had a problem with the 'factory reset' because I was using the Massoth PC-software which does not have a 'factory reset' option. If anyone knows how to do the reset using this software it would be really useful!
Anyway I have now installed the LGB (V6) software which does have the 'factory reset' option ...
For info, these are the values that are currently set on the decoder (directional lighting CV values look okay)
1,4,1-127,Loco Address (standard short)
2,0,1-255,Starting Voltage (in Speed Step 1)
3,3,1-255,Acceleration time
4,3,1-255,Braking time
5,255,1-255,Top Speed
7,23,--,Software Version
8,123,123,Manufacturer ID: Massoth
9,0,0-3,Motor Frequency
13,0,0-3,Function Outputs in Analog Mode (On if value set)
17,192,128-10239,Long Loco Address (High Byte)
18,128,128-10239,Long Loco Address (Low Byte)
29,4,Bits,Configuration Table NMRA (see documentation)
49,5,1-32,F1: Dimming Value (PWM)
50,5,1-32,Light: Dimming Value (PWM)
51,1,Bits,F1: Command Allocation (see documentation)
52,128,Bits,Front Light: Command Allocation (see documentation)
53,64,Bits,Rear Light: Command Allocation (see documentation)
54,50,Bits,LGB Confiuration (see documentation)
56,5,1-32,F2: Voltage (Smoke Generator)
57,1,Bits,F2: Command Allocation (see documentation)
58,0,0-255,Pause Time for Stop and Reversing
60,48,1-255,Back EMF Adjustment Factor
61,0,1-255,Back EMF Adjustment Speed
62,255,1-255,Back EMF Adjustment Strength
