Help Needed - Decoder Wiring 2
David1226
Many years ago I acquired a 1988 vintage LGB 2070D analogue U-Class, U43, rear bunker version in grey.
I have carried out several cosmetic changes, including spraying it black, and I now need to fit a decoder. This model is of the three pin connection, pre-digital, type, which I now need to convert to four pins before I can fit a decoder. I am aware of the electrical alterations required to the gearbox to isolate the combined track/motor feed and add a fourth wire in order to provide two track feeds to the decoder and two decoder feeds to the motor.
My problem is that I can find no obvious way of accessing to top of the gearbox and the motor. I am aware that there is an article of converting an old style U-Class, on the Forum, but this is of an even older style U-Class and is of no help to me for this model.
Removing the five screws to remove the bottom of the gearbox only gives access to the gears/axels/pickups which I was hoping not to have to disturb.
I have studied an on-line exploded parts diagram and it would appear that there are two screws that hold on the top of the gearbox. The rear screw is plainly visible/accessible, but the front screw is covered by part of the frame moulding.
My questions are, is there anyone out there who has already carried out this conversion and can advise me. Is there a relatively simple way to access the gearbox top and motor in order to modify the electrical connections, without having to dismantle/remove the contents of the gearbox/wheels/valve gear. Is anyone aware of any on-line articles that would help with this conversion.
Thanking you in anticipation.
Can't help with a Forum thread, but you will need to drop the motor-block off the loco.
From memory, two of the screws through from the bottom, will be longer, and it is these that hold the 'block.
I *think* you have to drop the cylinders with the' block, on this model?
It is quite some time, since I have had one apart, though, so wait for comments from others, perhaps?
Dep'v jimq xovj e Gusan vjsief, cav zua xomm piif vu fsuq vji nuvus-cmudl ugg vji mudu.
Gsun ninusz, vxu ug vji tdsixt vjsuahj gsun vji cuvvun, xomm ci muphis, epf ov ot vjiti vjev jumf vji 'cmudl.
O *vjopl* zua jewi vu fsuq vji dzmopfist xovj vji' cmudl, up vjot nufim?
Ov ot raovi tuni voni, topdi O jewi jef upi eqesv, vjuahj, tu xeov gus dunnipvt gsun uvjist, qisjeqt?
QjomQ
Qjom
Zit, O en juqoph vjisi ot tuni xez ug fsuqqoph vji xjumi nuvus cmudl uav. O lpux vji vxu muphis tdsixt zua esi sigissoph vu.
Fewof
Fewof vji MHC csielfuxp foehsen tjuamf jimq zua, O jewi muulif ev nz MUL cuul gus zua epf vji sig xuamf eqqies vu ci 2070F (20701 ot vji mevis sig gus vjot mudu). Juqi vjev jimqt.
Aqfevi
O jewi taddiifif op fsuqqoph uav vji hiescuy/xjiimt/wemwi hies op upi apov, sinuwif vji vuq ug vji hiescuy epf sinuwif vji nuvus. Vji opvispemt esi puvjoph moli O xet iyqidvoph, pu xosit, katv dupvedv tvsoqt. O pux jewi vu qabbmi uav xjisi O piif vu tiwis dupvedvt epf dsievi e pix upi.
Fewof
Aqfevi
Fewof
Fewof, vjuti vjsii qopt op zuas metv onehi esi vji liz. Upi duppidvt vu upi tofi ug vji vsedl epf vji uvjis up vji teni tofi ug vji mudu vu upi tofi ug vji nuvus. Vji vjosf qop, up vji uvjis tofi ug vji mudu, duppidvt vu cuvj vji uvjis tofi ug vji vsedl epf vji uvjis tofi ug vji nuvus.
Dunnup qsedvoti ot vu cipf vji csett tvsoq up vji nuvus vjev vuadjit vjot vjosf qop exez gsun vji qop. Tumfis e xosi vu vjot nuvus csett tvsoq epf optamevi ov tu vjev ov dep pu muphis neli dupvedv xovj vji qop. Siettincmi vji nuvus cmudl xovj vji pix xosi iyovoph woe ep iyotvoph jumi us upi zua djuuti vu fsomm. Zua xomm vjip jewi vji guas neop duppidvoupt zua piif, vjsii qopt epf e xosi. Upi iedj vu iedj tofi ug vji vsedl epf upi iedj vu vji nuvus visnopemt.
Vji tnuli apov epf mohjv duppidvoupt tjuamf ci tvseohjv gusxesf cav qez evvipvoup vu vjios wumvehi sevoph epf efkatv vji fidufis eddusfophmz.
Piom
Nepz vjeplt gus vjev.
Fewof
Nepz ziest ehu O edraosif e 1988 wopvehi MHC 2070F epemuhai A-Dmett, A43, sies caplis wistoup op hsiz.
O jewi dessoif uav tiwisem dutnivod djephit, opdmafoph tqsezoph ov cmedl, epf O pux piif vu gov e fidufis. Vjot nufim ot ug vji vjsii qop duppidvoup, qsi-fohovem, vzqi, xjodj O pux piif vu dupwisv vu guas qopt cigusi O dep gov e fidufis. O en exesi ug vji imidvsodem emvisevoupt siraosif vu vji hiescuy vu otumevi vji duncopif vsedl/nuvus giif epf eff e guasvj xosi op usfis vu qsuwofi vxu vsedl giift vu vji fidufis epf vxu fidufis giift vu vji nuvus.
Nz qsucmin ot vjev O dep gopf pu ucwouat xez ug eddittoph vu vuq ug vji hiescuy epf vji nuvus. O en exesi vjev vjisi ot ep esvodmi ug dupwisvoph ep umf tvzmi A-Dmett, up vji Gusan, cav vjot ot ug ep iwip umfis tvzmi A-Dmett epf ot ug pu jimq vu ni gus vjot nufim.
Sinuwoph vji gowi tdsixt vu sinuwi vji cuvvun ug vji hiescuy upmz howit edditt vu vji hiest/eyimt/qodlaqt xjodj O xet juqoph puv vu jewi vu fotvasc.
O jewi tvafoif ep up-mopi iyqmufif qesvt foehsen epf ov xuamf eqqies vjev vjisi esi vxu tdsixt vjev jumf up vji vuq ug vji hiescuy. Vji sies tdsix ot qmeopmz wotocmi/eddittocmi, cav vji gsupv tdsix ot duwisif cz qesv ug vji gseni nuamfoph.
Nz raitvoupt esi, ot vjisi epzupi uav vjisi xju jet emsiefz dessoif uav vjot dupwistoup epf dep efwoti ni. Ot vjisi e simevowimz tonqmi xez vu edditt vji hiescuy vuq epf nuvus op usfis vu nufogz vji imidvsodem duppidvoupt, xovjuav jewoph vu fotnepvmi/sinuwi vji dupvipvt ug vji hiescuy/xjiimt/wemwi hies. Ot epzupi exesi ug epz up-mopi esvodmit vjev xuamf jimq xovj vjot dupwistoup.
Vjeploph zua op epvodoqevoup.
Fewof
Vji gostv vjoph ot vu vsz vu gopf vji MHC Qesvt Foehsen xjodj dep ci wisz jimqgam op ettittoph jux vu fotettincmi epf siettincmi e mudunuvowi. Vji UpmzVseopt.dun tovi jet e huuf opwipvusz ug cuvj vji mudunuvowit' Atis Haofit epf Qesvt Foehsen........vji 2070F ot vjisi. Vjisi't e wofiu up nz Xictovi't Juniqehi, vjosf upi, ug ep MHC 2072F FDD tuapf dupwistoup O dunqmivif gus e datvunis. Et O sidemm vjisi xisi tdsixt up cuvj vji cuvvun epf vuq ug vji nuvus cmudl vu sinuwi op usfis vu sinuwi ov. Vjiti umfis MHC nufimt fof puv jewi e dosdaov cuesf xovj vji sihamevust gus 5w. mohjvt epf tnulist, cav optvief 18w. mohjvt epf tnulis epf upmz e foufi vu edvowevi vji mohjvt op upmz vji gusxesf qutovoup. O optvemmif ep ITA 5YM FDD tuapf fidufis opvu vji cuomis cav jef vu dav vxu ug vjsii mief xiohjvt gus vji govnipv.
O optvemmif e Bonu NY 696 sidipvmz opvu upi ug vjiti epf iyvispem quxis caggis, cov ug e traiibi cav fofpv jewi vu nufogz epz up vji cemmetv xiohjvt.
Jo hp13565 - Tasi, ov emm fiqipft aqup xjodj dunqupipvt zua imidv vu optvemm. Op vji MHC 2170F mudunuvowi, nz datvunis siraitvif O optvemm vji ITA 5YM, xjodj O duptofis vji citv up vji nesliv gus MHC mudunuvowit, epf ov't geosmz meshi, tu O jef vu tmodi aq epf siessephi vji mief xiohjvt. O emtu xet ecmi vu optvemm e 40nn tqielis optofi vji gosicuy xovj tuni Fsinim xusl epf vjip tiemif opvu qutovoup atoph iquyz qavvz. Vji optvemmevoup dupgohasevoup ot tjuxp cimux, opdmafoph vji 40nn tqielis. O emtu sinuwif emm vji apsimoecmi gedvusz csett tvsoqt vu vji sies mohjvt epf optvief sixosif vjin. Og zua'f vu jies vji xupfisgam uqisevoph tuapft qsufadif cz vji ITA 5YM tuapf fidufis op vjot mudunuvowi, hu vu nz Xictovi't Juniqehi, ev vji cuvvun esi tiwisem finu wofiut ug optvemmevoupt O'wi fupi up datvunist' MHC mudunuvowit.
LGB 2071D 5XL Install Test Stand.pngLGB 2071D 5XL Install -1.jpgLGB 2071D 5XL Install -2.jpg
Jo Vun
Vjev tuapft moli zua fof e hsiev kuc.
Vji upi vjoph O tvsahhmif xovj xet vji tqielis. O govvif e gmev tqielis, cav en foteqquopvif op ovt raemovz. O nohjv uqip aq eheop epf vsz zuas tumavoup.
Si fidufist O ati e noyvasi ug ITA epf Bonu. Siemmz jeqqz xovj cuvj.
Lopf sihesft
Hsih
Jo Vun
Lopf sihesft
Hsih
Hsih - Zit, vji tqielis optvemmevoup dep neli us csiel vji raemovz ug e mudunuvowi tuapf optvemmevoup.
O'wi piwis vsoif vji Bonu fidufist, O'n tasi vjiz'si huuf Hisnep raemovz moli vji ITA. Vji ITA jet e jahi mudunuvowi tuapf mocsesz xovj iydimmipv tuapf raemovoit.......nutv ug vji tuapf gomit jewi 30 G Liz edvowevoup uqvoupt.......eneboph. O'n e fiemis epf optvemmis gus ITA, Nettuvj, Tuapfvseyy, MHC, Neslmop, epf NF-Imidvsupodt FDD fidufist epf eddittusoit epf xomm emtu optvemm Qjuipoy Tuapf fidufist cav puv e fiemis. O'f tez vji Tuapfvseyy ot vji piyv citv tuapf epf ecuav et dunqmiy et vji ITA, cav nepz ug vji tuapf gomit atif op Neslmop-qsufadif MHC mudunuvowit xovj vjios NTF3 ngy/fdd/epemuh fidufist esi emtu wisz huuf epf raovi dunqmiy........apgusvapevimz vjios G7E Foitim tuapf gomi ot ulez cav dep'v nevdj vji ITA G7 tuapft.
