GWhizz
Offering Garden Railway Holidays in SW France
Hi,
Can anyone advise on Accucraft Blow down valves?
- I have an early (smaller cylindered) Accucraft Lyn on loan/ option to buy.
- No matter how much I tighten the blow down valve it will not seal
- I've unscrewed the outer hex tube and removed the valve inner to inspect
- I can see that the cone of the tap does not fit snuggly into the matching end of the tube, hence the leak
- ANY IDEAS on a solution ???
- I looked at the valves on my other Accucraft locos, but they seem to use a completely different design using O rings
- I tried using various O rings but does not work with this design ( they just ride down and block the venting holes
- Unfortunately DJB make a nice replacement system for most Accucraft but not the Lyn (the gas tank is too far back)
