Definitely Newquida as I suspected....
Bought from ECR just says Made in China underneath
So am I safe to assume that genuine Piko and LGB should couple together OK?
Thank youYes, I have both LGB and PIKO and i can confirm that they couple together with no issues....
Problem with Newquida is that the plastic is decidedly less strong than LGB or Piko, also these have quite long runs from bogie to coupling casing droop, thus unreliable coupling and uncoupling. The reason why I outed all my Newquida coaches bar 1 that hardly ever gets used.
I’ll still on my steep learning curve so that’s another thing ticked off, thank youProblem with Newquida is that the plastic is decidedly less strong than LGB or Piko, also these have quite long runs from bogie to coupling casing droop, thus unreliable coupling and uncoupling. The reason why I outed all my Newquida coaches bar 1 that hardly ever gets used.
It's the stacase of getting what you paid for. For someone who's starting out and wants to add to their stock quickly it's probably fine, and obviously easy to improveProblem with Newquida is that the plastic is decidedly less strong than LGB or Piko, also these have quite long runs from bogie to coupling casing droop, thus unreliable coupling and uncoupling. The reason why I outed all my Newquida coaches bar 1 that hardly ever gets used.
