Handsomerob
Catching the fever
So does anyone have experience with horsetail weed? From what I have read, it seems to be quite a tough weed to eradicate. I was wondering if anyone has any tricks to getting rid of it.
Horticultural vinegar with a 20% strength or stronger, normal vinegar might work, but it's normally around 5% strength.
It will need to be applied on a dry, sunny day.
I was only able to get some 10% strength around here so I have been breaking it off and spot treating the stocks with the vinegar, I hope it helps to at least control it.
Does it have seeds and flowers as such?A right bugger. Often called Marestail in England. SBK works on woody plants so not too sure it will work on these - good for brambles though
Crushing the plant first sounds a good idea - well worth a try.
I find the damn stuff comes up on disturbed soil if you don't do something with it straight a way - like the seeds are sitting there waiting!
It has a fragile tap root, and will regrow from any bits left behind, it also is resistant to chemicals due to the waxy nature of its stem and foliage in short a right bar steward
