homestyal said:Just wondering how you all couple your Roundhouse loco with central buffer and hook, to your LGB and Accucraft rolling stock?
I suspect a change of coupling on the LGB and a two/three link chain to your Accucraft..........8|
Mossala Hill said:All my loco's, including Roundhouse, and almost all my stock have Accucraft chopper couplings fitted. I do have a pair of LGB log wagons and as they always run together I've not bothered to replace the loop and hook coupling that joins them. This means that if I acquire anything with loop and hook I can marshal it in between them and run it straight away until I get round to fitting choppers.
I also have an Accucraft Caledonia with the factory fitted coupling at the scale IOM height, and although it looks frightening it easily couples to the rest of my stock which have couplings at standard height and has never (yet!) come adrift.
Rob
That's an interesting post Graham. Do you find this with the leading coupling on the first IOM coach set to IOM height to match the loco, or do you mean it lifts if you 'make do' with the leading coupling on the coach at the factory setting of the lower '16mm' height? I can see how the latter would lift but it is only two screws into factory drilled holes to change the coupling to IOM height.pghewett said:The problem with differing chopper heights as between the Accucraft IOM locos and the Accucraft IOM stock is not that the choppers won't couple, it is that because of the height difference, the loco tends to lift the vehicle immediately following it, so de-weighting the front axle/bogie. This leads to derailments especially on switches and crossings, reverse curves below R3 and so on. Note this can also be a problem with the chain and coupling bar solutions unless the lengths are very carefully adjusted.
Graham Hewett
Very impressive, Bob.Mossala Hill said:Caledonia in full cry with new Summerlands chuffpipe pulling standard coupling height stock:
Ah, right, yes, it does indeed get a tad complicated Graham! I think in your situation I'd settle for one end of one item of IOM rolling stock to be set to IMR loco height, then you can either run with it at the front of a rake if using an IMR loco, or put it at the back if using a non IMR loco (or just park it in a siding).pghewett said:I entirely agree that one way round the problem would be to adjust the couplings on all the Accucraft rolling stock. I would then be able to couple it to Caledonia - but - I wouldn't be able to couple any of it to my Countess...
Life is full of difficult choices!
GH
An excellent fuel stop!Sea Lion said:...reference to 'a good choice of bars' has nothing to do with the Mines Tavern at Laxey!
