Steve said:Nico ,
I bought some of the track cleaning material same as the LGB track cleaning loco wheels
http://www.massoth.com/index.en.html
Product reference Cleaning Pads for LGB 50050
Put power to the wheels through a spare peace of track or wires and let it rub against the wheels .
Or i have seen people with the OO brush cleaners .
trammayo said:I just wonder if the LGB cleaner is abrasive - if so it will take a micro layer away of that plating on your wheels. I use meths because it is alcohol and evaporates - it really does disolve the crud - I only use abrasive methods as a last resort. The brushes seem a better idea.
Chris M said:My meths has just run out and now I'm going to use isopropylalcohol. This has been recommended to me by a guy who repairs 00 locos for a living. He also uses it to remove transfers. Sounds like pretty useful stuff.
How do you get it? From your local chemists but they will probably have to order it for you.
, Isopropynol
nico said:, Isopropynol
Did you ever try paint spirits
trammayo said:No - its too oily (if you mean turps substitite or the white spirit which is sharper). I've tried poteen but you need a high alcohol content really. Steve mention brushes which would loosen any stuborn dirt. I just soak the cotton bed well, and as soon as it gets dark, use the other end and get another until it remains clean.
I've often thought that dirty wheels can cause pitting on the wheel tread as the current might arc to make contact and so errode the surface. But then I'm as guilty as the next man - only cleaning wheels when the loco behaves as it shouldn't.
Mick
PS - the idea od powering the loco as Steve mentioned is a good one. As most of mine are steam outline I just lay the loco on its back and put a couple of crocodile clips (with wires of course) to the pony truck from an old OO gauge transformer/controller.
New Haven Neil said:Isopropyly alcohol = Isopropanol = ethanol I think? from your pharmacy, at least you can get it from them here!
