twister25f
I'm trying to figure out what to do to get chuffing with a Phoenix sound P8 decoder. It is in a Bachmann 4-6-0 (starter set engine) that I just put an Airwire P4 in. I didn't realize the Phoenix steam sound board did not have anything to trigger the chuffing. The P8's I've put in USA diesels apparently automatically change the sound based on speed which is what I thought this would do but apparently you need a magnet and sensor for the steam version. What have you used and where do you get such things and is there a trick to installing it? Everything else is working good on it, just that when it's moving the engine sounds are just idling sounds. Thanks!
