Miamigo259
This could fit into the usual "Kit Bashing/Scratchbuilding" thread, but as it refers to an item of interurban tramway rolling stock, it might as well go into the tram section!
It is still a "work in progress", but will be updated at various points until the model is complete.
A couple of years ago, I picked up a secondhand Bachmann baggage car at one of the GSS shows for the princely sum of £15 and thought that it would be a suitable basis for conversion into a US style electric interurban goods railcar, something along the lines of this one which is preserved at the Electric City Trolley Museum in Scranton, PA....
This one was owned by the Philadelphia and Western, a third-rail operation that still operates between 69th St in Philadelphia and Norristown, though it is now the Norristown High Speed Line operated by SEPTA. The car was latterly used as a works car by SEPTA and was additionally fitted with trolleypoles.
I had looked around for a suitable (ie cheap...) motor block to use in constructing the unit and had not come up with anything until a few months ago, when after comparing the dimensions of a battery chassis that I had bought with a loco body kit, i thought it would be possible to use one of those, rather than the original plan to have a track powered unit.
The chassis in question is a Houston Gate Loco Works product - a laser cut wooden chassis frame with motor, wheels etc that looks like this...
and at less than £20 for a 4-wheel drive version it wasn't going to break the bank, so I bought one to carry out some haulage tests. If it hadn't turned out to be suitable, I wouldn't have lost out as it would have ended up as another 4 wheel shunter with a scratchbuilt body.........
However, it actually fitted the bill perfectly, so it just needed some work to transform it into a sutable match for the original bogie it was replacing. Some stripwood was used to create a cradle to attach it to the (doctored) chassis of the model, and the centre sections of the original Bachmann bogie sides were cut down by about 0.5" to match the slightly shorter wheelbase.
Once the bogie sides were attached, the cut-down Knuckle coupler arm was attached to the new bogie and dummy third-rail beams & shoes were made from scrap material and fixed to the frames....
Then the other original bogie had the shoe beams fitted..........
To be continued.............
