ge_rik
Has anyone else encountered problems with IP Engineering gearboxes. I've stripped the gears on two of mine with only minimal / light use. I get the impression the plastic gears used are not really strong enough for the loads to which the models are likely to encounter.
I've tried replacing one set with a Cambrian brass worm wheel / steel worm replacement but it's not a direct fit and my engineering skills are not sufficient to make a reliable gearbox keeping the gears in mesh. I'm growing increasingly frustrated.
Has anyone found a reliable gear / motor replacement for those sold with IP Engineering kits - eg- http://www.ipengineering.co.uk/page61.html
and .....
Rik
and .....
Rik
