stevedenver
i use distilled water-exclusively
is there any harm in leaving the boiler partially filled, say, for months at a time?
i can only imagine that even with emptying, there is enough moisture to do the same, if any, as if filled?
ditto for steam oil
i always drain the gunk and water while hot, and then re-fill while hot/warm to aid in flow
any issues here ?
again sometimes i run a lot, sometimes they sit for months
the only thing i do empty religiously is to remove batteries each and every time for the Rc transmitters and receivers
ditto for steam oil
any issues here ?
