artfull dodger
Here is a video and a pic of my Lady Anne kit I am building. Just got the chassis done, cranks pinned and timing set. Forward will start up on 8-10psi and stay running on as little as 5psi air from my airbrush compressor. Reverse takes a bit more to get it running, mostly from the valve gear not being in full reverse till I get my hand freed up to pull it into full gear. Reverse is around 15-18 to get it started, but settles down to 10-12 to stay running. Cant wait for the boiler to show up so I can run on steam. Next step is to make a mount to the crossmember to mount the Regner whistle steam line so it will support the whistle body. Cheers Mike
