StephH
7/8ths and 1/12th modeling in Railways and Birdwat
Hi all,
After failing miserably to find anyone with a Ragleth power chassis for sale
(even from the new batch that is available soon) and that was my best plan for a 7/8ths loco. I may have had a rough idea for a loco using a Lawley power chassis though.... but to see if it would work I was wondering if anyone out their with a Lawley could run a ruler over it for me please?
I need the overall length of the running boards from buffer beam to buffer beam and the width. The length of the boiler and smokebox plus the distance from the front of the smoke box to the buffer beam and the distance from the rear of the boiler to the rear bufferbeam ( so I can locate the boiler on the plan properly). Also a good idea of the positions of the dome and safety valves if possible.
I assume the gas tank (size etc) and footplate layout is the same as the Edrig?
Edit.... I see on a photo I've just seen the gas tank has an extended filler pipe etc to fit in the cab.... that may scupper my plan depending on its location etc but we shall see....
Mind you whilst I play with this idea I'll bet no one will have any of those chassis either...
especially in my price range
......And whether it would work rather depends on these measurements!
Thanks
Steph'
Thanks
Steph'
