Yes, i'm quite sure Alan, as the Middle wheel pivot is higher than the others.. :thumbdown:stockers said:Neil is quite correct. If you dare try to adjust the quartering on one axle you need to check it against ALL the others - not just its truck or 4 or 6 wheels.
If the loco has had a hard life, the coupling between the drive units could be worn. I am not sure if this can actually be 'out' of quarter.
Are you sure the problem is with the quartering????
Different manufacturer, Totally Different loco.. and an extremely different GearboxDeutsche Reichsbahn said:I had the same with my Piko BR80. Failing gearbox...
