Dean Palmer
After much searching and not finding people with a similar issue I figured I'd ask here. My 2055 White Pass Alco has a problem where the headlights come on in the wrong direction. They shoot backward when going forward, and to the front of the engine when going backward. The engine runs forward with the flashing red light going, and the bright whites shining on the rolling stock behind it. I took it apart and there is nothing odd or miswired. It has a PH Hobbies sound card installed but that doesn't seem like it would have any effect. The plugs for the front cab and the rear lights on the main circuit board are different and not able to be swapped (3 wire to rear, 4 wire to front). The trucks are all plugged into the correct front/rear pins on the circuit board. Just nothing seems wrong, and my other 2055 works perfectly with correct lighting.
