beavercreek
I had a good day testing right into the night and discovered something that is not quite right with my streetcar. It is the one with MTS and sound.
I run analogue with TE (using on linear not PWC). The inerior lights flicker at low or high voltage but not in any particular piece of track. Other locos do not exhibit this problem except for when crossing one or two of my switches (points).The street car just does it anywhere but not consistently!
Sometimes the interior lights go off and do not reappear for some time. The head light is always fine as is the sound (except for one or tewo points where it rings the bell and starts up again).
I cleaned the track, the skates and checked the wheels.
At times the flickering is very slight but at others it is practically continual. This, as I said earlier, happens at low voltage or high (slow or fast).
Is there a way of using a back-up super capacitor with the lights? I do not want to rip out the incandescent bulb wiring and change them for LEDs as it will mean a lot of amending of a good LGB item. But if this is the only way to go then has anyone done this?
