nlevasseur
Normally, I can find answers by searching the previous posts but not this time… Newish to this forum, and have been doing more with G scale LGB more recently. So I picked up a 51750 off eBay and when I hooked it up to test it with a signal switch motor, two of the rockers worked great while the other two were non functional.
I searched all previous posts on the forum and found nothing similar as to some faulty rocker switches. I have not metered anything.
The 51750 is hooked up to the ac terminals on a LGB transformer with short leads.
Functional meaning they would actuate the 5094 signal switch motor in both directions.
Non-Functional meaning they would not actuate the 5094 signal switch motor in any direction.
I used the same 5094 for testing each of the 4 rocker switches just moving the leads to the white and orange terminals for each rocker switch.
I took the bottom of the 51750 off, but there is no way to get at the other side of the circuit board and rocker switches.
Any ideas? Does it sound like the diodes on two of the rockers have gone bad? Any way to get at the other side of the circuit boards and rocker switches?
I have other 51750 that work just fine.. Thanks for weighing in.
