Is there anyone who could offer some guidance on resetting the old LGB 55021s? I've attempted to factory reset 2 of them, but it seems that my efforts are not yielding the desired results (my indictor is that CV1 isn't defaulting back to 3 and instead keeping the original loco address)
I had a look at the manual (via onlytrains.com) which says CV55 should be set to 55. This writes successfully but doesn't seem to reset. I then saw that in some systems you had to set CV6 to 55 (to register it as CV55 you want to write to) and then CV5 to 55 (to write that value to CV55). That doesn't seem to have taken either.
I'm sure the problem is with the user (me), but I haven't yet worked out why.
To confirm, there is a load on the decoder (a loco/motor) with no other components attached.
