I unplugged the two black one brown lead from the PCB and it stopped the constant clanging. So now I need to figure out how to get it working properly.In early DCC days..
This could be F2 set to toggle, rather than momentary. - But would depend on which function the bell is activated by?
I would think the reed-switch, or its wiring could be trapped / shorted somewhere. - A three-wire lead, running from the board in the motor-block, to the circuit board.
If you are lucky, two black, one brown wire (for identification).
If not, three black, and you might have to investigate a little harder.
Could still be a trapped wire shorting brown to one of the blacks?I unplugged the two black one brown lead from the PCB and it stopped the constant clanging. So now I need to figure out how to get it working properly.
Clip wires onto the skates for power..I wish I was more knowledgeable on electronics. How do I go about shorting the reed switches in turn?
I did put a different reed switch in the tender from another similar tender and the whistle and bell both worked fine. I'm guessing the whistle side of the switch has an issue.
Thank you so much for your help and responsiveness from across the pond.
