Thanks Steve. That's good as I have some 5V ones.Nemo said:Im sure they are 5 Volt Keith.
stevelewis said:Hi Keith
Think they are the 18v ones but I could be wrong,( if they screw in they are if they are the ones with the 2 thin wires they are 5v ones)
I have just got a Black one ( Gubbins version!!) it came from South wales!! and is Mallet number 6 in a long line of Mallets!!
could be, try turning it on?KeithT said:The loco isn't mine BTW.
I have found another enigma, it is fitted with a Massoth sound card but I can't raise any sounds from it. Apparently, when it was last used in October it worked OK. It is stored in an unheated brick garage. I am aware of the dangers of condensation affecting MTS gear in such a place but had not heard of locos being affected. Could that be the cause?
Zerogee said:stevelewis said:Hi Keith
The push-in bulbs (with the two short wires) can be either 5v or 24v - to tell them apart, the 5v ones have a FLAT end to the bulb (the "top" end opposite the wires) while the 24v type have a ROUNDED end. Jon.
The old screw-in (usually yellow) bulbs to fit much older locos are, as Steve said, 18v.
I am surprising myself!!!! After having been into LGB since'75 but taking a 2 year break from G scale
it is surprising how much one forgets!! (or is it just old age!!)
Is there a switch? 8|Phil said:could be, try turning it on?KeithT said:The loco isn't mine BTW.
i know it sounds daft but i've done it before..![]()
If it's digikal, try number 6KeithT said:Is there a switch? 8|Phil said:could be, try turning it on?KeithT said:The loco isn't mine BTW.
I missed this as i was sending you a PM!!
Dun that, the silence is deafening.&:Phil said:If it's digikal, try number 6KeithT said:Is there a switch? 8|Phil said:could be, try turning it on?KeithT said:The loco isn't mine BTW.
I missed this as i was sending you a PM!!![]()
