Hi all,
Does anyone know How LGB axles are assembled in the power blocks? I know on Piko the gear split the axle in the sense the axle of each wheel sits each side of the plastic gear which acts as an insulating spacer.
Reason I ask is I want to convert an LGB power unit to gauge 3 (63.5mm gauge). I thought GRS could do it but it appears not, so not sure the project will work as I have no lathe.
Thanks
Si
Thanks
Si
