Dinas Bryn
Evening I have the CFV Mallet fitted with LGB sound and MTS, I would like to fit the DR with another perhaps better sound any ideas? Les
muns said:Replace the decoder and sound with a Massoth XLS (8210085) - use a Massoth DCC Onboard adapter (8150701) to connect the existing wiring to the XLS.
Or replace the sound board with a Massoth S sound unit (but I'm not sure what sounds will be available for that yet).
Hi Les, sorry but could you clarify 2 points:Dinas Bryn said:Evening all returned from the NW Meet earlier with my Mallet with sound, putting it on the Potty Line it is a lot better than the LGB unit Many thanks Phil Les
Aljosha said:Hi Les, sorry but could you clarify 2 points:Dinas Bryn said:Evening all returned from the NW Meet earlier with my Mallet with sound, putting it on the Potty Line it is a lot better than the LGB unit Many thanks Phil Les
- Is this now a Massoth sound, and if, which make number please?
- Is this now doing a genuine Mallet chuff, as audible on the mallet.de website? = specific Mallet sound?
dunnyrail said:Philo,
do you think that you could let us know what CV's you changed and to what value to set the chuff rate up? I have a couple of puffers with Massoth Chips and get fed up with only 2 beats to the resolution of the drivers. I worked out how to do it with LGB built in sound, but not in my 0-8-0 as they do not now supply you with full cv listings on current LGB.
