<p>Hi Cliff, </p><p>It stopped raining and I got one of my LGB native DCC loks out for test. I was a bit surprised at the results. </p><p>With a Massoth Digital Command Station 1200Z set to automatic (ie, lok in database, lok status preserved) my Massoth chipped lok will resume the previous set speed and direction after an emergency stop or main power off. If the speed control was set to stop before resetting / powering up the system, the lok will still accelerate to speed with the handheld flashing a discrepancy. If the system was not set to remember the lok status, then the lok would remain stationary when the system was reset or powered up. If the handheld speed control was not at stop it would flash as a discrepancy until the control was set to stop. In all cases the sound and lights would be on if they had been on before the interruption. </p><p> With the same central station in automatic setup, the LGB chipped lok would not restart after a power off, and the lights would no longer be illuminated. The handheld would flash a discrepancy until the speed control was set to stop. After an emergency stop, the lok would accelerate back to speed with lights again illuminated. In both cases the sound would automatically restart. If I switch off the sound on the handheld then restart the system the sound does not come on until I operate the appropriate key, but if I operate the shutdown sounds and wait till the lok is silent then after a reset the start up sounds and standing sounds automatically come on. </p><p> So there are clear differences in the way that the Masoth XLS and the LGB decoder operate after a power interruption, although they seem to have similar responses to an emergency stop. While I do not have your unusual sound behavior, I have a lighting variance, but nothing that requires a switch to be operated on the lok. </p><p>What version of software do you have (value of CV8)? My LGB chip is version 30, manufacturer code (CV7) 123 = Massoth. However the manufacturer code for LGB is 159, so its possible my pre-owned RhB Ge4/4 III has been rechipped, but its the spaghetti Albula special version so I doubt it. I have also noticed in my LGB 'manual' that CV54 has two bits for sound, but no explanation of what they do. I tried setting them and could not find any changes on a very quick test. CV54 does something completely different in the Massoth XLS decoder (sets which function key controls lights). NMRA RP-9.2.2. states that CVs 47 to 64 are reserved for manufacturers use.
</p><p>Sorry this has probably been no use in solving your problem, but at least I was inspired enough to fit the two way switch to my programing track, after its been sitting about waiting for me to find some enthusiasm. So thanks for that! </p><p>Don </p>
