KeithT
Thinking caps on please... a friend brought a couple of locos to a running session this afternoon. The first is the blue Orient Express Mallet, Cat' No. 21852 (although on opening it up I found one of the lead weights with the number 22852 cast into it).
The loco had "not been used for a while".
At the first attempt the front power block was sticking, the motion seemed OK but lacking lubricant. It ran reasonably in reverse and after some cajoling it ran forwards but with intermittent sticking of the front unit.
Another bit of "added value" was the lights which refused to switch respond to Command 9. However, on most circuits the loco would falter momentarily in the same location at which point the lights would flash on and off! It wasn't possible to cause it to happen by jolting the loco. Eventually I was "volunteered" to have look at it and at least lubricate it. On getting it home I realised that it had not had the most cherished existence some previous owner having fitted five different screws to hold the body in place two of which were woodscrews. Incidentally, is the fitted card the standard LGB one? It has a volume control hidden under the middle dome. (I am not too impressed with the sound, it is blurry. Poss' a poor speaker?)There is a 3 pin plug lying "spare" at the rear of the body.
There were no loose connections although I taped a couple of suspect bare patches on some shrink tubing.
After lubricating it I removed the baseplate expecting to see mangled gears but they were well lubed and in perfect condition.
On testing it on the rollers the rear power truck was now the one reluctant to move! After a little persuasion it ran reasonably but the the speeds are not matched, sometimes the front runs faster and sometimes the rear one.
The only clue I have to what might be wrong was that after the first running session I thought that the smoke generator had been operating because the upper front end was noticeably hot but the next check showed that it wasn't the generator - it doesn;t work at all.
So, could it be a sick motor(s)? Seems unlikely that both have gone intermittently sick at one and the same time.
The second loco was this one. It weighs a 'ton'.
All it needed was oiling. I am not a particular fan of Forneys but this is the second one I have seen which looks far better in the flesh and the slow running is superb. There is no Cat' No. on it - odd.
PS I don't 'do' electronics so if it is the card at fault then it is "over and out" for me!
nphone:
