James Day
Guano Corner Rly - Runs weekly - Guano permitting
I have had LGB catenary for quite a while and the child in me demands that I run with the pantographs up and where possible collecting power through them.
I have the original stainless steel LGB catenary and run locos and trams with the red single head panto and the bow collector.
I tend to use graphite grease on the panto heads every now and then to reduce wear and learned early on that the actual head from the red panto can be unclipped and replaced with carefully bent brass rod. This has enabled me to keep my pantographs going, rather than replace them.
Despite many years of use I have not yet worn out a bow collector head, although I have reprofiled one of mine when it began to 'rut'.
I bought a second-hand 2034 (green and white) steple cab, and was amazed to find the head peice was stainless steel, so that was quickly removed and replaced with a home made brass one.
The only real issues that I have found when running from the catenary has been the sometimes poor connection betwen the base of the pan and the wire coming up to the pan from the switch. This is a very creaky compression contact and I feel that soldering it would be a lot more positive and reduce the ressistance. Has anyone done this?
Finally, I have a spare pair of the Crocodile typepans with the twin head. Has anyone used these under the contact wire? I do have a Croc, but feel it is too big for my catenary equipped branch lines!
James
James
