Noticed a different sound then usual while running... I took it of the track to inspect. The tender (motors) is NOT the source of the "sound" or problem it all moves fine. The engine main body IS where the problem is. It's lubricated ok. So, I put it on its side without the tender and manually spun the drive shaft by hand. It moves perfectly in reverse direction but when I go forward spinning the shaft it sort of "binds" at the same two spots each rotation... again not in reverse tho. I see nothing visible obstructing any moving parts and it appears the 2 trucks and gears are not the source of the problem. It does rotate forward it just requires more force to rotate. It seems like the binding is in the cam-cylinder-rod area but can't be 100% sure. Anyone have any experience with this?
Thanks for your help!
