LGB Spremberger question
playmofire
23 Oct 2010
8,291
856
80
North Yorks
Although I have a number of Playmobil steam outline tank locos and the Playmobil 4502 2-4-0 tender loco, my favourite loco is an early 2750 LGB Spremberger I bought some years ago off eBay for £80 with its nice, chunky businesslike shape.
I've been after another one for some time, but the price has shot up to silly levels, over £100 at times for an early version, plus I want one with the long projections on the cylinders intact. However, I recently bought one, again off eBay, for £94.95 from footplatetrains.
Like my first one, it runs well from the start but there are three of differences - the bell is silver instead of gold, the buffers have a white edging and there are a couple of terminals in the cab floor which the other doesn't have. Both are marked as made in Western Germany.
Any ideas as to what the terminals are for and year of manufacture would be appreciated.
tac foley
11 Apr 2017
4,314
1,012
78
Near Huntingdon, UK
The long projections on the cylinder fronts are call tail-rods, and actually protected the projecting ends of the piston rod from weather and damage.
1,721
Have the terminals volts?
playmofire
23 Oct 2010
8,291
856
80
North Yorks
Thank you, Tac; I end the day a wiser man which makes a nice change.
idlemarvel
Neither idle nor a marvel
13 Jul 2015
3,136
801
Ascot
Mars
According to LOK it is a 2075 made between 1974 and 1982. The picture on p 79 of LOK shows the silver bell, white edging around the buffer and screw in the front. Looking at the LGB Kompendium vol 1 p 110 it could be edition 4 as the early editions had no bell, so likely to be an 80's model.
playmofire
23 Oct 2010
8,291
856
80
North Yorks
Thanks, Dave.
-bbbb
21 Dec 2017
589
129
Idaho
No, no sign of anything.
Maybe they aren't terminals, which raises another question - what are they then?
I have no idea what they are intended for, but it looks like they could be used to hold a figure in place.
playmofire
23 Oct 2010
8,291
856
80
North Yorks
An interesting thought as I intend to add a crew. I think I may also do a light bulb test to see if they are live when power is fed to the loco's wheels.
Madman
3,019
Pennsylvania, USA
Looks like a clamshell motor block. I've seen them with similar terminals atop them which make contact for lights, in some locos.
5,019
76
A quick touch to one of the screws to each side of the wheels or skate with a Meter if you have one wound confirm that for you.
-bbbb
21 Dec 2017
589
129
Idaho
if not terminals for a light, maybe terminals for a speaker, for some kind of sound?
Keith RhB
23 Oct 2012
617
7
Canada
Didn’t they also make a battery version of that loco? Could those terminals be for battery connection?
5,019
76
Probably not, the battery one had plastic wheels and if memory serves the batteries went in the boiler
