beavercreek
As I have had a bit of a problem with inconsistent chuffs when using reed switches or the Bachmann Annie chuff trigger with the Uintah/Sumper mallet soundboards that I am putting in the Annie tenders, I am going to try hall effect sensors instead, as these are what LGB use for most of their in loco sound cards. I got the LGb soundboards pretty cheap from a German supplier on ebay and they work perfectly.
What I am not sure of are some of the specs that those hall sensors would have. The spec that I am pretty sure of are:
Operating voltage 3V to 24V
Output current 20mA
Current supply about 6mA
Open collector
Connections for GND, CLICK and +12V
BUT
should the sensor be bipolar or unipolar or other?
Latching or non latching?
The Massoth hall sensor replacement kit 8242030 only gives a few specs for the sensor and the kit comes with axle and magnetic ring which I don't need. I have sent an email to Massoth but just in case anyone has had to buy a replacement hall sensor on its own and knows the spec.........
Output current 20mA
Open collector
BUT
