All used but only indoors. Mostly boxed FWIW. None have rail joiners attached as I use rail clamps. If you don't use rail clamps I will supply the appropriate number of new rail joiners with each piece. Please let me know if you want rail joiners when you order. You can have the whole lot for £290 £90 or individual lots as below. P&P to UK mainland address will be £5 per order. Please PM me if interested. Exciting pictures of track below.
CROSSING £15
LGB 13100 90 degree
ELECTRIC UNCOUPLERS £25 each
LGB 10560 150 mm x 3 (all working with motor and "E" light)
ELECTRIC POINTS (with motor) £25 each
LGB 12150 R1 left hand x 3 2
LGB 12050 R1 right hand x 1
MANUAL POINTS £15 each
LGB 12000 R1 right hand x 2
BUFFER £5
LGB 10310 (working light)
CURVES £18 the lot
LGB 11000 R1 30 degree curves x 7
LGB 11020 R1 15 degree curves x 4
STRAIGHTS £17 the lot
LGB 10000 300 mm x 3
LGB 10150 150 mm x 2
LGB 10080 82 mm x 3
LGB 10070 75 mm x 2
LGB 10050 52 mm x 1
LGB 10040 41 mm x 1
CROSSING £15
LGB 13100 90 degree
BUFFER £5
LGB 10080 82 mm x 3
LGB 10070 75 mm x 2
LGB 10050 52 mm x 1
LGB 10040 41 mm x 1
