viaEstrecha
I bought one of these as a donor loco but it is too nice to cannibalise and so I have stripped, repaired and refurbished it for possible re-sale. It is the posh one with lights, smoke and sound under analog, with extra functions if you add a decoder for MTS (which it doesn't). I bought it with a declared issue with the lights - now all lamps work but perversely, opposite to the selected direction of travel!
All ribbon cable connectors are unique and keyed, so I haven't reversed or muddled any, I am stuck. Unless a board has an internal problem, I can't see what is up or why the lights are reversed. There are these red switches which I think are set for no MTS - the documentation advises setting them to 'Off for MTS', though that is not obvious from the marking, nor how they should be for basic analog.
I suppose one way to fix the problem might be to carefully fiddle with the ribbon cable to the motor block shown bottom right below, to swap over the two outer wires to the motor (marked as 'yellow' and 'green', though helpfully it is a black cable)? That ought then to make the motor run forward and back to match the lights, I'm assuming.
Just seems a bit bodgy to do that, so I thought I'd ask here, in case anyone has a better suggestion.
