Zerogee
Clencher's Bogleman
When using the Ansmann Li-Ion packs, all of which come with a built-in protection board, is it OK (read: safe) to connect two or more packs either in parallel OR in series, or will that cause problems with the individual protection circuits and/or confuse the charger?
The reason for the question is that while 14.8 volts and 5.2Ah can be most easily achieved by a single 4S2P pack like this:
http://www.rapidonline.com/electric...attery-pack-li-ion-4s2p-14-8v-5200mah-18-4128
there will be some loco applications where this pack, although very compact for the power it provides, still won't physically fit.
In such a case, there would be two possibilities for achieving the same total voltage and capacity - either two of these:
http://www.rapidonline.com/electric...ry-pack-li-ion4s1p-14-8v-2-6ah-inline-18-4126
in PARALLEL, or two of these:
http://www.rapidonline.com/electric...ry-pack-li-ion-2s2p-7-4v-5-2ah-inline-18-4122
in SERIES. Either set-up would still give 14.8V with 5.2Ah capacity, but is such a connection safe to do, or is it setting up potential (no pun intended) problems...?
