PatsRailway1
Newbie here. I have bought a second hand lgb starter set and I want to know if I can use the Lionel battery sets coaches only with the lab loco. Thanks in advance
that depends, how they are made.Can I cut down to 45mm
I should think so..Thanks Is it possible to replace with metal wheels and axel
I would see if you can replace the bogies with LGB or PIKO ones. You would then have LGB compatible couplings as well as the correct 45mm gauge wheel sets.Thanks Is it possible to replace with metal wheels and axel
