BritishGScaleModdeler
A while ago now I purchased two Lionel 'G scale' Harry Potter sets and another set of coaches (total of 6 coaches) They were the correct track gauge but terrible out of scale to gauge 1 which I normally model. The only parts that were near to gauge one are the windows!
I know the earlier versions released by Hornby were not 45mm gauge but the newer ones are.
This got me thinking, I wondered if I could convert them so that they could be used with some of my gauge one engines!
I've cut up 6 coaches, stuck them together and enlarged them in every direction, I've ended up with 2 standard, 1 buffet and 1 guard end. I've also constructed and made interiors for each coach.
The first of the 4 coaches is nearing completion, while the other 3 are at varying levels of the assembly line!
I stuck the newly constructed roof on tonight of the first coach and also added interior lighting.
To go from essentially toys to what they are now is such a transformation, they haven't come up bad have they!
The original coach minus chassis dimensions : 7.4cm wide, 28cm long and 8.2cm tall.
New dimensions: 56cm long, 10.7m wide, and 9.2cm tall
