A powered live frog will almost completely eliminate point "stutter" for track power, and is very popular in the small finer scales, having no "dead rail", whereas LGB for example is not only dead frog but does not even have point switching to allow points to isolate tracks. For me, if I were using track power live frog every time, but it is what is produced by the big manufactures'.I get that one is powered and the other isn’t but why would you choose powered vs unpowered?
Oh there is a firm in Germany that do conversions for LGB Track. Can’t remember who, perhaps someone with a better memory than me can post a link?Thanks guys - appreciate your clarity and patience. As i run either DCC or occasional battery power I may have to convert my “live“ frog to a dead one (!) or figure out some funky wiring. (Phil S - agreed; have been using a Massoth power buffer for some time and point stutter has been eliminated.)
Your controller should be able to deal with the short i.e. shut down OK, but the train will stop.So overall, I think what folk are saying is that
live frogs aid certain locos to traverse points at slow speed, but
they require discipline in use to ensure “push throughs” don’t happen as this could/would cause a short circuit (depending on how the point blades and frog are wired).
The IOM steam at Port Erin has push throughs, or so I am lead to believe. I am sure somebody will correct me if I am wrongYour controller should be able to deal with the short i.e. shut down OK, but the train will stop.
I have a pet hate against push through for any model railway setting - the scale weight ratio doesn't really stand up to the concept IMHO
