Shawn
Hiking, cross country skiing, snowshoeing
Yesterday and today i took my Accucraft Forney out for some running. While running I noticed it does not run as fast. I have throttle etc. up all the way and the speed is very slow compared to what it was. It chugs along at a perfect speed around the layout but thats at full throttle. It use to take off at full throttle.
-The pressure is fine pop valves goes off at arounf 40 and while running pressure stays at around 30.
- Im not seeing any steam leaks and the temp is perfect for seeing steam.
-the cyliders leak some water at the start but not during running as far as I can see.
-The pop valve will go off throughout the run and burner runs fine.
-The only thing different is the temps are colder outside. Today it was low 40's and sunny. I dont remember it running this slow in the cold weather last year.
Any ideas on what could be the issue or is it just the air temp being cold?
Two possabilities that were mentioned
Something partialy blocking the throttle valve (I took apart and blew it out etc.... will test tomorrow).
the oil being used. (I have been using the accucraft steam oil from day one)
Any other ideas?
My next step will be run it in my garage and see if there is a difference.
A second question how do you know when the timing is off and how do you fix?
Any other ideas?
