gregh
A couple of wet days kept me inside so I decided to make a few signs for my stations etc.
The method I use is to print a mirror image of the sign on clear plastic. This is then 'stuck' to the required backing so that the ink side is under the 'glue' and protected from the weather.
For text only, I use WordArt and drag the text across itself to produce the mirror image.
Or you can use MSPaint or other photo editing program to produce a bmp picture of your words and/or picture. Then mirror image the final result using the 'rotate' or 'mirror' functions.
Here?s an example of a page that contains some station name boards, level crossing signs and some beer adverts for my pub.
Now print on clear plastic, such as used for overhead transparencies. I get my local print shop to do this for a better result than my bubble-jet can do. Costs a whole $4 for an A4 colour page. Note that what shows white on the screen will be clear when printed.
Now you have a clear sheet with the ink on the back when you look through the plastic. Turn it over and paint over the whole sheet including the printing with white acrylic paint so as to not dissolve the ink. After that coat is dry, I use the same paint to 'glue' the plastic to a styrene backing. Some of my signs have been outside for 15 years now with no deterioration. This method of using the paint as a glue only seems to work well for signs over say 3 sq inches. Less than this as there?s not enough ?stickiness?.
This is some of the beer signs from the above example, ?painted? onto 0.5mm styrene
And installed?.
And this one is 14 yrs old ? the wood dowel posts are rotting but the sign is fine!
And installed?.
