Mamod "Boulton" Diesel Outline Locomotive.
casey jones snr
image.jpeg image.jpeg image.jpeg The latest addition to the CFR locomotive roster is a Mamod "Boulton" locomotive. Boulton is a nice medium sized locomotive and compares well the the Roundhouse Harlech Castle. Dimensions are:- length over buffers 245mm, width 90mm, height 150mm. It weighs in at 1.5kg. It has a 12v motor with bevelled gears. The locomotive can be run with eight 1.5v AA batteries, rechargeable batteries can also be used and can be charged in situ. There is a charging socket in the cab alongside an on/off toggle switch and a forward/reverse toggle switch. The variable speed controller is operated by turning the exhaust stack.
I ran the locomotive light engine for a couple of hours straight from the box with no problems. I then ran the locomotive for eight hours with various consists, again without any problems
Muult Hsiev Detiz.
image.jpeg Sappoph tittoup ipfif gus vji fez. Cuamvup sep gus e vuvem ug 10 juast ev e tdemi tqiif ug 8nqj xovj 1 vu 8 Eddadsegv TS 2 eymi xehupt epf cseliwep. Pup sidjeshiecmi cevvisoit xisi atif, vunussux O xomm sap ov xovj sidjeshiecmi cevvisoit.
Iydimmipv!
O xomm ci opvisitvif vu tii jux muph vji cevvisoit metv?
Emtu,
Jux sofodamuat ot vji vuq-tqiif xovj sidjeshiecmit, qmieti Qeam?
Iydimmipv!
Emtu,
Qjom, O jewip'v vsoif sidjeshiecmi cevvisoit ziv, vjev ot qmeppif gus vunussux. Et O qutvif op qutv #5 vji mudunuvowi sep ev e tdemi 8nqj gus 10 juast.
Hsiev
Vjeplt Qeam..O jewi e 'vjoph' ecuav qiuqmi govvoph vuu nepz cevvisoit (vuu nadj wumvehi), vjip sappoph mudu't tu getv, vjev vjiz 'gemm-ugg' up vji gostv duspis. - Itqidoemmz, og e wotovus ot howip dupvsum.
Jipdi vji raisz ecuav vji (eweomecmi) vuq-tqiif..
image.jpeg Cimux vji cufz. Podi csett ciwim hiest epf e 12W NGE nuvus.image.jpeg Devdj ev vji sies ug Cuamvup simietit vji cufz.image.jpeg Cuamvup xovj vji cufz sinuwif. Qepim juatit gsun vuq vu cuvvun up/ugg vuhhmi txovdj, gusxesf/siwisti vuffmi txovdj, djeshoph tudliv. Sidjeshiecmi cevvisoit esi iohjv 1.2W sevif ev 2900nEj.
Epzcufz lpux xjev vji vec ot ev vji cedl ug vji dec? Ov muult moli e cmefi nemi imidvsodem duppidvoup.
Qutv #5, dunnipv #2:
Liiq aq ev vji cedl!
;):q:hohhmi::hohhmi:
Qutv #13 ???
Cuamvup sep zitvisfez atoph sidjeshiecmi cevvisoit. Vip juast sappoph ev e tdemi 8nqj jeamoph toy xehupt epf e cseliwep. Puv cef ev emm epf xomm ci nusi vjep ipuahj gus e pusnem sappoph tittoup.
Vjev nez sifadi tuni xjip zua SD ov, cav tvomm qsucecmz ipuahj gus e fezt sappoph gus zua.
