This is sound very old school ... but.... I use on board battery R/C, which is obviously DC. I use Fosworks which has great functionality equal to DCC for my needs. I have the capability to program an Arduino Nano. So far, I have ascertained that if I connect the motor to the 'track power supply' input to the smoke unit then smoke will be produced. However, can the unit cope with +/- and then -/+ (reversing)? This is not really a problem because I can use a Nano with a MOSFET to create smoke using +/-. The advantage is I can program the Nano to vary the smoke volume according to speed. The issue I have is the 'clock sensor' input. It has three wires. Does anyone know if the wire labelled 'not connected' is actually used ie is this say 5volt positive? Otherwise does the hall effect sensor 'short' the 'clock in' to GND? But this needs a supply the the hall effect detector. I can see that using DCC that the decoder might operate the fan speed using different voltages. I assume this is PWM but I do not know the frequency?
My questions are:
1. to create smoke confirm I can use a straight DC (6-14.4 volts) onto the 'track power' cable?
2. how can the fan be operated without DCC?
My questions are:
