Yes F is Function, so for lights F9, sound F6 or F8.Thanks for the info.
still no joy.
my kit is 55015. No P. The central unit is 5505P.
there is an “F” on the controller. Do I need to press that before all the numbers you have been referring to? Sorry if that’s a really daft question.
Try again and report back....
I stand corrected Mark!surly, with the loco selected, you should only press the number of the function (1 to 8, 9 for lights) you wish to trigger and NOT the F button followed by the number!
Pressing F triggers a special operation, ie. F then 9 toggles between serial and parallel commands for the selected loco. F then 1 changes to Accessory mode (S--) so that you can change a point.
By putting my controller in parallel I can now operate the newer locos properly. That works fine now other than directional lights which still won’t cooperate.
thanks for all the replies.
