Hi Les,
The Massoth 4 Channel Switch decoder allows you to specify any awitch address for each of the 4 outputs (unlike the LGB 55025 which limits you to a sequential block of 4 addresses).
To program the switch decoder.
1) Connect it to your programming track.
2) Connect a point motor to the SW1 terminals
3) Unlock the decoder by setting CV2 to 77
4) Program the relevant CVs (see later)
5) Lock the decoder by setting CV2 to 0
6) Connect to the main track feed and test.
For switch addressed 1 through 255:
Output 1 (SW1) - Set CV31 to 0 (default) & CV32 to the address value (i.e. 5)
Output 2 (SW2) - Set CV33 to 0 (default) & CV34 to the address value (i.e. 6)
Output 3 (SW3) - Set CV35 to 0 (default) & CV36 to the address value (i.e. 7)
Output 4 (K5/K6) - Set CV37 to 0 (default) & CV38 to the address value (i.e. 8)
If you need to increase the pulse duration, two CVs for each Switch output must be changed.
Output 1 - CV51 & 52
Output 2 - CV53 & 54
Output 3 - CV55 & 56
Output 4 - CV57 & 58
These determine the mode and duration of the output. For LGB switch motors this value should be 67 (monoflop operation, 3/4 sec). Add 1 for each additional 1/4 sec duration required.
Hope that helps.
