OBBherr
I decided to test my backup PC Module, which as far as I know has never been used. Connected up using LGB power supply (works fine with my usual module). It's the older module version which allows AC or DC due to internal rectification.
When switched on, red light flickers and goes off (should stay on). When powered off, light flashes briefly and goes off. This occurs regardless of whether its connected to the laptop with MST.
So it looks as if the unit has failed but I thought I should at least ask here if anyone else has seen this behaviour, and what the outcome was. And as a long shot has anyone had one repaired?
Thanks for any insight that you can provide.
