Another batch of goodies. All items used but working and complete with manuals when provided. P&P to UK mainland £4 for one or many items. I have numbered the lots to make it easier to tell me which ones you want. I'd rather not break the lots down further. Pictures at the end in order of appearance.
Note there is second part to this post below as there is a limit of 20 pictures per post!
ONLY LOTS 3 and 11 LEFT!
1 - ROLLING ROAD x 2 £40
Massoth 8101200 Rolling Road x 2
Provides 4 axle rollers and 2 skate supports
![20230702_143802.jpg 20230702_143802.jpg](https://cdn.gscalecentral.net/2023/07/thumb/485712_20230702_143802.jpg)
2 - TRACK ACCESSORIES JOB LOT £10
LGB 50040 Track Cleaning Block
![20230702_143826.jpg 20230702_143826.jpg](https://cdn.gscalecentral.net/2023/07/thumb/485713_20230702_143826.jpg)
www.lgb.com
PIKO 35285 Track Clips x 20 and LGB 11500 Track Clips x 40
![20230702_143837.jpg 20230702_143837.jpg](https://cdn.gscalecentral.net/2023/07/thumb/485714_20230702_143837.jpg)
www.lgb.com
PIKO 35292 Insulated Rail Joiners 3 packs of 6
![20230702_144058.jpg 20230702_144058.jpg](https://cdn.gscalecentral.net/2023/07/thumb/485716_20230702_144058.jpg)
LGB 5025 Track Stop Blocks pack of 12 (now LGB 10250)
(picture to follow)
www.lgb.com
3 - AUTO-UNCOUPLERS x 4 £15
LGB 1052 Manual (auto) uncoupler x 4
![20230702_144219.jpg 20230702_144219.jpg](https://cdn.gscalecentral.net/2023/07/thumb/485721_20230702_144219.jpg)
www.lgb.com
4 - POINT MOTOR £15
LGB 12010 Point Motor
![20230702_143919.jpg 20230702_143919.jpg](https://cdn.gscalecentral.net/2023/07/thumb/485722_20230702_143919.jpg)
www.lgb.com
5 - POINT SWITCHES x 4 £15
LGB 12060 Manual Point Switches x 4 (they also work with PIKO points and LGB uncoupler track in place of motor)
![20230705_121136.jpg 20230705_121136.jpg](https://cdn.gscalecentral.net/2023/07/thumb/485723_20230705_121136.jpg)
www.lgb.com
6 - POINT LANTERNS x 4 £20
LGB 12040 Lighted Turnout Lantern (German) x 4 (choice of 3 left and 2 right)
![20230705_120851.jpg 20230705_120851.jpg](https://cdn.gscalecentral.net/2023/07/thumb/485724_20230705_120851.jpg)
Note: I have never tested the lights
www.lgb.com
7 - POINT DECODERS x 2 £20
LGB 55024 Single Point Decoder x 2
![20230705_121049.jpg 20230705_121049.jpg](https://cdn.gscalecentral.net/2023/07/thumb/485728_20230705_121049.jpg)
www.lgb.com
Note: no instructions, see here for PDF download
8 - ACCESSORY DECODER £20
LGB 55025 Four Channel Decoder boxed with instructions.
![20230702_144014.jpg 20230702_144014.jpg](https://cdn.gscalecentral.net/2023/07/thumb/485726_20230702_144014.jpg)
Each port can be configured for points or lights.
www.lgb.com
9 - EPL JOB LOT £40
Variery of LGB and PIKO EPL equipment. This lot would be over €160 new.
LGB 1705 Sound Activating Track Magnets x 2
![20230702_144237.jpg 20230702_144237.jpg](https://cdn.gscalecentral.net/2023/07/thumb/485730_20230702_144237.jpg)
www.lgb.com
LGB 17010 Train Magnet x 3
(picture to follow)
www.lgb.com
LGB 1710 Track Sensor (old style - reed switch - untested)
(picture to follow)
LGB 17100 Track Sensor (reed switch - untested)
www.lgb.com
(picture to follow)
PIKO 35272 Track Sensor (reed switch) x 2
(picture to follow)
LGB 11152 Curved Separation Track R1 15° x 2
![20230704_165601.jpg 20230704_165601.jpg](https://cdn.gscalecentral.net/2023/07/thumb/485732_20230704_165601.jpg)
www.lgb.com
LGB 10710 Trackside Cable Holder x 8
![20230705_121227.jpg 20230705_121227.jpg](https://cdn.gscalecentral.net/2023/07/thumb/485734_20230705_121227.jpg)
www.lgb.com
10 - COACH LIGHTING JOB LOT £30
Checked the lights all work. This lot would be over €150 new.
LGB 63193 Metal Wheel Electrical Contact Set x 4 (pairs)
![20230702_144346.jpg 20230702_144346.jpg](https://cdn.gscalecentral.net/2023/07/thumb/485736_20230702_144346.jpg)
www.lgb.com
LGB 68331 European Marker Lanterns x 5
![20230702_144354.jpg 20230702_144354.jpg](https://cdn.gscalecentral.net/2023/07/thumb/485738_20230702_144354.jpg)
www.lgb.com
LGB 68333 Coach Lighting Kit
![20230702_144248.jpg 20230702_144248.jpg](https://cdn.gscalecentral.net/2023/07/thumb/485740_20230702_144248.jpg)
www.lgb.com
11 - DC CONTROLLER AND POWER SUPPLY £60
All working. This lot would cost over €200 new.
PIKO 35006 DC Analog Throttle/Controller (0-22 V 1.6 A)
![20230702_144453.jpg 20230702_144453.jpg](https://cdn.gscalecentral.net/2023/07/thumb/485742_20230702_144453.jpg)
![20230702_144507.jpg 20230702_144507.jpg](https://cdn.gscalecentral.net/2023/07/thumb/485744_20230702_144507.jpg)
PIKO 35005 DC Power Supply IP67 (22 V 32 VA)
![20230704_163657.jpg 20230704_163657.jpg](https://cdn.gscalecentral.net/2023/07/thumb/485746_20230704_163657.jpg)
PIKO 35270 Track Power Clips x 3
![20230702_144128.jpg 20230702_144128.jpg](https://cdn.gscalecentral.net/2023/07/thumb/485748_20230702_144128.jpg)
(MORE TO COME - 20 PICTURE LIMIT HIT - SEE PART TWO BELOW)
LGB Track Cleaning Block | Märklin
This is an economical method to clean your rails easily and gently. The cleaning pad removes dirt from the rails without harmful abrasives. The 6 mm / 1/4"
![www.lgb.com](/proxy.php?image=https%3A%2F%2Fwww.lgb.com%2Ftypo3conf%2Fext%2Ftorr_template%2FResources%2FPublic%2Fimg%2Ffavicons-lgb%2Ffavicon-32x32.png&hash=91e72498478c50b56d0a4ad659c69dd6&return_error=1)
Track Clips, 28 Pieces | Märklin
The track clips keep track sections from coming loose, even during heavy use. They are especially useful for flex track, LGB roadbed, and on temporary layo
Track Clips, 14 Pieces Buy modeltrains | PIKO Webshop
Track Clips, 14 Pieces Buy modeltrains from PIKO | PIKO Webshop ✓ Top quality ✓ Fast shipping ✓ Excellent support
www.piko-shop.de
G Isolier-Schienenverbinder 6 Stck. Buy modeltrains | PIKO Webshop
G Isolier-Schienenverbinder 6 Stck. Buy modeltrains from PIKO | PIKO Webshop ✓ Top quality ✓ Fast shipping ✓ Excellent support
www.piko-shop.de
(picture to follow)
Wheel Blocks, 12 Pieces | Märklin
Wheel blocks are used to keep cars in place on grades and on sidings and keep them from rolling away. A package has 12 pieces
Manual Uncoupler | Märklin
This is a manual uncoupler for cars with standard LGB hook-and-loop couplers. The manual uncoupler can be installed in straight sections of track. When sym
Turnout Mechanism | Märklin
This electric turnout mechanism is easy to install on all LGB turnouts. You can even control your trains automatically by combining this mechanism with the
Manual Turnout Mechanism, 2 Pieces | Märklin
The LGB manual turnout mechanism can be used on both indoor and outdoor LGB layouts. A package contains two manual turnout mechanisms that can be used t
MTS Turnout Decoder, Single Channel | Märklin
This new turnout decoder allows you to transmit commands for an LGB solenoid accessory through the track. The decoder is powered directly from the track, w
MTS Turnout Decoder | Märklin
With this decoder you can transmit power and commands through the track for your LGB turnouts, signals, and accessories. You don’t need long, complicated
Sound Activating Magnet | Märklin
This sound activating magnet turns sound effects on in many sound locomotives. It can be clipped easily into most LGB track.
(picture to follow)
This magnet activates the 17100 LGB track contact. It mounts easily under LGB locomotives.
(picture to follow)
Track Contact | Märklin
This small, electrical contact can be used to control LGB turnouts, signals, and other accessories automatically. It is activated by a locomotive equipped
(picture to follow)
G-Track Contact Buy modeltrains | PIKO Webshop
G-Track Contact Buy modeltrains from PIKO | PIKO Webshop ✓ Top quality ✓ Fast shipping ✓ Excellent support
www.piko-shop.de
LGB Curved Separation Track Radius R1 15° | Märklin
Using LGB garden railroad track will give more dynamic to your layout as easy as child’s play. Simply put the track together and you can get started. LGB
Wire Holders, 5 Pieces | Märklin
These wire holders help keep your wiring manageable. The holder attaches to the side of a section of LGB track. The wires can then be laid easily in the op
Electrical Contact Set, 2 pieces | Märklin
The economical way to add track power pickups to most twin-axle LGB freight and passenger cars. Includes four brushes, two brush holders and screws. Requir
European Marker Light, 18 Volts | Märklin
Install this authentic lantern on the end of your passenger or freight train. The lantern is lighted for nighttime and has warning markings for daytime ope
Interior Lighting Set, 24 Volts | Märklin
Light up your LGB passenger cars with this easy-to-install interior lighting set. The set includes one light, mounting screws, and two connecting wires. Ju
G-Basic Analog Throttle 22V / 1.6A + 16V DC Buy modeltrains | PIKO Webshop
G-Basic Analog Throttle 22V / 1.6A + 16V DC Buy modeltrains from PIKO | PIKO Webshop ✓ Top quality ✓ Fast shipping ✓ Excellent support
www.piko-shop.de
G-Transformer 230/22V DC,32VA, Buy modeltrains | PIKO Webshop
G-Transformer 230/22V DC,32VA, Buy modeltrains from PIKO | PIKO Webshop ✓ Top quality ✓ Fast shipping ✓ Excellent support
www.piko-shop.de
G Anschlussklemme mit Kabel Buy modeltrains | PIKO Webshop
G Anschlussklemme mit Kabel Buy modeltrains from PIKO | PIKO Webshop ✓ Top quality ✓ Fast shipping ✓ Excellent support
www.piko-shop.de
