stevedenver
the PIKO series is often so simple and sterile-so i tried to add some bits from stuff i had, to soften these plastic blocks.
The weathering , somehow , looks better in person than in the harsh , flash lighting here, (simply india ink and some white acrylic from a tube with some dilution to look like leaching)
i plan to overspray something a bit muddy too, as well as eventually adding something to the open window areas on the ground floor-trying to think of something other than a real interior and furnishings-will also add lighting in and out
since my layout gets a fair deal of water and sun, i try , if i can, not to paint too much, as i fear it will become another maintenance issue-the PIKO plastic looks like plastic, but im hoping with a few layers of overspray it will improve a bit -stuff i add is usually chosen to stand weather, like this canvas on plastic with plastic covered wire supports on the awning, as well as total loss from mishap and handling and general inattentivness on my part
i added the awning, made from a bit of odd POLA bit that fit and some old canvass from an about to be discarded car cover in the garage -
it hides the cavernous vacant front floor
added the POLA paper shades -as these things are just so bare out of the kit-although i was impressed with the quality of these and ..no cut- -them-out-yourself acetate windows!!! stryene panels like POLA !
added the entry floor with gumball, and the flower boxes in front of the windows, and all the stuff on the roofs but for the stacks-and i might change one out to leftover brick POLA
