schienenkönig
I'm a tram enthusiast and have made trams Scale G
In an empty, not used salesroom the scouts tram lay out is running for more than 17 days. Every day from 10 to 19 o'clock. The tram need round about 38 seconds for a complete ride. That means 849 rounds where made during a day. It started on the 26th March and goes on till the 20th May 2015. (If the shop is not sold)
It has only a timer clock. The length of the track is ~ 18,10 Meters. That means in 19 days it made 292 km = nearly 182 miles. And that means marks comming onto the curved tracks.
The shop window.
The tram with the trailer in the middle is the oldest of my models. I had to change only the scates and one time the brushes to the motor. The tram is nearly 18 years old know. The shape from the front part is different to the first scartch build. I'm really surprised, that this modell run all the time since 1987. And now when it does the propper job, I had only once a failure with it. The coupling felt into the tracks and the motorcar runs into his trailer. After a circle the train derailed and suck. The wheels still running an made marks into the rails. A 3mm screw whre lost.
After 17 days of service I noticed a wearout at the curved tracks. It left these little chips near the rail, mostly on the outer rail. At the straight rails, you see only a pile of black brass chips.
Have you had similuar experiences with the tracks?
Peter
The shop window.
Peter
