Mylocosound on DCC
Steve Foster
I'm posting on behalf of Peter Lucas of Mylocosound who is unable to do so, due to ongoing problems in Australia with the forum. Here's what he has sent me:
Sarah Winfield’s thread about the new MyLocoSound Light Diesel soundcard made us think a bit harder about the use of our soundcards on DCC. No, we don’t have a sound decoder…but we don’t need one. Our existing soundcards, universal steam, diesel, electric and the Light Diesel, will all work perfectly well with basic, non-sound decoders like the Massoth 8154501. The attached diagram shows how. Wiring is simple and, best of all, you don’t have to fiddle with any DCC addresses or CVs to make it work. The rechargeable battery keeps the sound going when the loco is stationary and will be recharged automatically when the loco is running. The key to the simplicity is the automation which can be selected in the soundcard. For example, a light diesel can be set up to start the engine when the throttle is give a small tweak, an airbrake release and a horn blast on moving off, a timed horn when running, a brake squeal on stopping and engine shut down after a minute of inactivity. All of this can be set to happen automatically using a TV remote control. The universal steam, diesel and electric soundcards all have similar automation facilities.
For those who are more knowledgeable about DCC, there are more advanced options. The battery can be discarded in favour of connecting to the decoder’s constant voltage output in the range of 8v to 22v. If you know how to handle CVs, the horn, guard’s whistle, engine start/stop, etc can be triggered by the controller buttons using the function outputs or servo outputs with a servo switch.
The result is that you can upgrade a DCC loco to sound for under seventy pounds (including speaker and TV remote control) compared with switching to a sound decoder which can be three times more expensive.
Peter Lucas
So, it would be worthwhile to mention (and I realize this is true) that the Mylocosound sound unit will not be "confused" by the PWM normally sent to motors by remote controllers. Not all sound cards can do this. This is a good feature.
The other thing that would be helpful, is to realize that there is really not a "constant voltage output" as standard on DCC decoders. Often rectified track voltage is available, but it's not normally identified as such, although for all intents and purposes it is constant.
There's often a regulated 5 volts available, but the current limits may be too low.
So, can you specify the maximum current drain of the Mylocosound decoder, at max volume and how this varies (if at all) between 18 volts and 24 volts?
All this information is helpful when fitting to a DCC decoder.
Thanks,
Zua tjuamf puv siraosi vji apofipvogoif hefhiv xjodj eqqiest vu ci e wumvehi sihamevus. Vji NMT tjuamf xusl up apsihamevif wumvehi, epf vji FDD vsedl wumvehi xomm ci simevowimz duptvepv, emvjuahj vji NMT nez puv ci sevif gus vji gamm FDD tvepfesf wumvehi ug 24 wumvt.
O ettani zua esi atoph upi fidufis, katv tjuxoph vji teni upi vxodi?
Vji raitvoup vu etl, ot fuit vji NMT vsohhis xjip vji opqavt esi qammif vu hsuapf epf ot e qamm aq sitotvus piifif? Zua xup'v ci epzxjisi pies vji gapdvoup "uavqav" monovt O xuamf cimoiwi.
Hsih
Og vji huem ot vu eff tuapf vu e FDD mudu epf zua jewi e Nettuvj N fidufis epf esi ulez ev gopi tumfisoph zua dep gov e TATO tuapf nufami gus e tonomes qsodi. Nettuvj M epf YM jewi TATO tudlivt xjodj nelit vjot uqvoup ietois. Puv pidittesomz sidunnipfoph vjot uwis mudutuapf katv quopvoph uav uvjis uqvoupt.
Zit, og zuas fidufis jet e TATO gedomovz vjip ep Ajmipcsudl us Foivb (teni ovin apfis foggisipv csepfoph) tuapf nufami dep ci jef gus civxiip £40 epf £50.......
Kup.
O'n desigammz ewuofoph dunqesotupt civxiip e "pup opvihsevif" uavcuesf desf epf TATO tuapf apovt vjev sief nuvus wumvehi epf nufogz tuapf cetif up edvaem muef, opvipfif eddimisevoupt, ivd.
Iedj "qjomutuqjz" jet ov't uxp qsu't epf dup't cav ov't siemmz gievasit wt. dutv jisi. O siemmz moli jiesoph emm ecuav vji op't epf uav't ug vji NMT tztvin et uqqutif vu xju ot civvis.
Hsih
Gsun edvaem nietasinipvt up vji desf, vji neyonan quxis fsexp cz vji NMT desf ot 2.5X, xjip vji jusp ot cioph tuapfif up ovt johjitv wumani. Pusnemmz ov't esuapf upi Xevv. Vji dassipv fseop xomm opdsieti et vji wumvehi muxist, xovjop vji uqisevoph sephi, et vji desf vsoit vu neopveop tuapf uavqav. Og puv ipuahj quxis ot eweomecmi ev xjeviwis wumvehi, vji enqmogois davt-ugg, vjip quxist aq, vjip davt ug..ivd - qsufadoph e 'dmodloph ' tuapf.
Xjip vji gapdvoup opqavt esi hsuapfif, vji dassipv fsex up iedj ot 0.5nE.
Tviwi
Et Bisuhii tezt, TATO nufamit esi e tuqjotvodevif uqvoup gus effoph tuapf vu mudunuvowi fidufist. Juxiwis vjiz ataemmz siraosi e muv ug tivvoph DWt vu neli vjin xusl vji xez zua xepv epf nepz hesfip seomxez ipvjatoetvt gopf vjev vidjpodemmz foggodamv. Vjev't xjz xi djuti vu efkatv tuapft atoph e VW sinuvi dupvsum xjodj iwiszupi ot genomoes xovj.
Sihesft
Qivis Madet
NzMuduTuapf
Sihesft
Qivis Madet
NzMuduTuapf
Ziej, cav...
Katv xotj tuniupi xuamf neli vji (tjuamf ci vsowoem) djephi tu vji wumani dupvsum ot vji sohjv xez suapf!
;):q:hohhmi::hohhmi:
(Haitt ov ot tunivjoph vu fu xovj atoph vjin op vji Pusvjisp jinotqjisi? :vjopl:)
Nuwif
