![United-Kingdom Country flag](https://gscalecentral.net/misc/flags/shiny/32/United-Kingdom.png)
My two cents...it looks like it was only the gussets that bent. I would try to gently pull it back into position then take a look at how the gussets fared. Those that look to be too damaged could then be replaced. Use a length of lumber flat against the right side to spread the strain as you pull it back into position. I would clamp on the right side toward the top of the bridge (in the picture) and pull the end closest to the camera toward the left bracing against a length of lumber clamped along the bottom on the left. The lumber on the left needs be small enough to allow the bridge to be pulled slightly beyond vertical so that it will rebound to vertical when the pull is released. Make the lumber as long as will fit in the space available to spread the load. You might find it straightens with minimal damage. Probably would help is there was a convenient grandchild in the teens to handle the grunt work.My elderly mate John slipped and fell on his bridge.
I'd like to get it repaired for him but my mechanical engineering skills are limited.
So could anyone suggest how I go about it, or could help me get it straightened please....
