stevedenver
I have an old mts 3 and 55015p controller, i am clueless about digital and MTS operation.
Earlier today, after much button pushing, i finally was able to access the MFX functions.
I was running, one locomotive at a time, my 3 mfx lgb locos, on a loop, individually.
Somehow, i was finally able to figure out how to :
1 enter the loco address,
2 use the key pad buttons on my 55015p to activate functions.
2 of my lgb mfx locos are address '3'; (Alexander theimer i1 saxon), and a IVk saxon. Both ran fine , smokes, all the stuff , simply entered the loco address number and each worked. They were never on the track together, but were run one at a time.
1 other MFX loco, Franzburg, address 5 , also worked fine.
I did run Franzburg and Thiemer on same track and was to control each.
Then...I believe.........i put on a massoth equipped, emotion equipped loco (saxon1k #54), at the same time as the mfx saxon1k Theimer , (i believe, but I am not sure what i did). I wanted to run the two locos on the same track....i am not sure of the second locos, #54s) address, i assume it was 3.
Now the mfx saxon Alexander Theimer won't respond to anything other than stepped speed commands. I enter address "3" , but, all buttons on my handheld operate ONLY the whistle. Very annoying. I suspect that the MFX has flipped to DCC??????
How would i get it back to MFX ? (not sure this assumption, is accurate at all BTW. Nor am i absolutely certain of what i did, wasnt paying attention until things didnt work.)
However, Franzburg loco at address 5, STILL works properly ,handheld buttons correctly activate functions.
I am guessing that having 2 locos with loco address 3 at the same time was the problem???
I know less than zero about mts digital , but am trying to learn.
I read that the mfx will recognize dcc or mfx automatically.
I suspect that the mfx saxon1k Theimer is now on DCC,(having recognized the #54 as DCC????
as the button commands arent working as they did earlier today.
I have tried resetting the mts unit, tried "F" and "0" ,
I have tried putting the MFX Theimer on the track and powering up, entering loco address, nada.
Franzburg loco, adress "5" still works and responds , handheld buttons operate functions.
I am unable to figure out what to do to get the Theimer loco back where it was.
help!
please make your directions step by step and really simple.
i am very frustrated and am struggling to figure out what i did to change the theimers operation.
i have also tried pressing and holding "F" on the different buttons, and just cant seem to decipher how to get it back to where to function buttons work correctly.
help!
