stevedenver
i am having diffiuclty keeping up adequate pressure
no steam leaks, cleaned the jet
all screws, wheels, linkages etc are tight and proper, as well as lubed
using water bath for gas pressure
any help or thoughts?
i am thinking i may get some stainless steel mesh and wire and wrap the burner to spread the flame
but
at one time the loco seemed to keep pressure better-
it will reach blow off, but then, after a a single loop run, slight grade, about 70 feet, runninglight-it will drop from 2.2 bars to about 1.5, then another loop (just barely crawling over the peak of the grade, it will drop to 1.1 and need to stand , throttle closed, to build pressure
some help would be greatly appreciated on whats going on
but
