Zerogee
Clencher's Bogleman
I know there are several threads already on similar subjects, and I've just been skimming through some of them - but I thought it was worth asking a specific question or two separately in case Those Wot Know Stuff About Batteries can help with some direct answers.... so here goes.....
I'm converting just one or two locos to battery power and the Tam Valley DRS control - I've got the control boards and stuff now (thanks Muns!
) but haven't yet chosen or purchased any loco power batteries. I want to keep away from LiPo or Li-Ion, for the simple reason that I want something which can be safely charged IN the loco - I want to be able to install the battery pack(s) semi-permanently with a charging socket wired in, so I don't have to disassemble the loco every time I need to recharge the batteries. I do realise of course that this means I'll only be able to run for a certain length of time per day with an overnight recharge, but I can live with that.
My thoughts at the moment are to go with NiMhs, probably 2 x 8-cell packs in series to give me 19.2 volts output - which should be plenty to drive the Massoth XLS sound decoder (the DRS receiver handles up to 24 volts). I haven't decided 100% which locos are going to get converted first, but just for the amount of internal space available my LGB whizzy-cranks 2095 is a likely candidate.
So, question 1: what sort of cell capacity should I go for to get a decent few hours of running time from a twin-motor LGB loco, with sound? Would packs of AA cells be enough, or should I look at sub-C cells?
Question 2: any particular type/make of NiMh cells to look for? Should I avoid the unbranded "generic" types available online?
Question 3: using a 9.6 volt NiMh charger, is it a) possible, b) safe and c) practical to charge two 8-cell packs IN PARALLEL simultaneously? What I have in mind (though I confess to not having worked out the wiring yet!) is the wire the packs through a switch that toggles between running and charging modes, such that for running, the packs are in SERIES, and for charging they are in PARALLEL. Can this be done, or does it throw up any obvious problems that I've not thought of?
As I mentioned above, I'm not particularly worried about fast-charging - I'm happy with an overnight trickle charge to keep everything safe.
Over to you, chaps, all constructive advice welcomed!
